When setting up a project for all disciplines with multiple view types and building areas, placing the views on a sheet itself is a tedious task when you have to do it once, but being a BIM manager for a large Design Build firm with all disciplines in house multiplies the work 5 fold, with no control over making sure that the area plan views are placed on each sheet for each discipline the exact same way other than to do it manually. Currently the only way I know of doing this is through RushForth tools project setup tool.
