Make text line weight adjust contour thickness
Currently (well, ok, R23) there is an attribute to text entities called line weight which does not seem to do anything. The idea would be to fix this bug and let it alter the text font's contour thickness.
If the parameter already does something, please let me know in the comments.
Comentarios
It currently changes the thickness of the leader and border. The test has it set to 7.
@Mike.FORM Thank you, I always thought these lines were dealt with the same way as ceiling plans or hatch pattern lines. Good to know. I retract my original 'idea' and ask for a way to adjust the line width of text contours.
