Pipe insulation visibility
Since Revit 2024 Pipe (and duct) insulations will automatically be hidden when the host is hidden.
This reduced the posibilities concerning visiblity of pipes and insulations.
insulations should be subcategories of pipes and ducts.
At this point in time it's not possible to have pipes hidden but the insulation still showing. Manufacturers sometimes create models for the insulations separately so they can be hidden easily as a whole. There's an option to hide or unhide the pipe insulation category but if it's turned on it can still be visible if the host is hidden. This seems to be confusing and limiting in what possible with regards to visibility of insulation.
