Instance parameters that should be editable.
I work at and electrical contractor. So my example below is for electrical. However I believe this may be a want for other trades as well.
To simplify, almost all parameters that control dimensions, offsets, or elevations. Should be editable.
In my example, I have the need to be able to edit the highlighted parameters when i select a conduit. Otherwise i have to spend time going through sections, elevations & 3d views to modify something.
Request is that any parameter that controls a dimension, offset, Elevation, X,Y,Z. Should be editable in the instance parameters of properties.
Comentarios
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
El estado se ha cambiado a: Archived
