Since tags associate themselves to the bounding box of an object. There should be a switch option on tags that allow it to got to the outside of the bounding box, or the center of the object. Only option currently available is to change tag to Free end. This allow you to manually drag the leader to the center of the object. Se my photo. I have a junction box placed. When i tag attached. it goes to the outside of my clearance zone i have on the box. The clearance zone is for internal use only and when i print sheets for permit or construction i turn off the clearance zone. However the tag will still be to that boundary and the tag does not look like it is attached tothe junction box. I have to change to free end and drag to the center. This is a lot of manual input.
Idea would be to add a checkbox toggle on tags that would alllow the tag to go to center of object rather than the outside.
