Justice for the Structural View Templates
Architecture has 2 main plan_view types: floor plan and RCP (Reflected Ceiling Plan). So does Structure: formwork plan and reinforcement (rebar) plan. Please, make justice for Structure and add clear and distinct view templates in the default Revit template file. View templates be like:
- Formwork Foundation Plan
-Rebar Foundation Plan
-Formwork Floor Plan
-Rebar Floor Plan
-Formwork Framing Plan
-Rebar Framing Plan
-Formwork Section
-Rebar Section
P.S. Structural Framing Elevation is good by default, as it is used mainly for steel structures (hence no formwork and no rebars are involved).
Comentarios
You can create view types with different templates. Only thinks is if you use Structural Plan View (family), non-structural walls will be hidden.
