Visibility of tags
It would be nice to be able to control the visibility of different tags of the same type in different views. For example, I need to show MEP ducts described by dimensions and flow rate in some views with dimensions only, in others with dimensions and flow rate as well.
It is often necessary to derive a drawing for a building permit from the execution drawing and therefore simplify the labels.
Then I don't want to change all the tags, just some of them. I want to keep for example the ducts dimensions (that's the duct tag) and turn off the duct flows (that's the duct tag too).
Comentarios
Tags are only shown in a single view... If you want tags of any type in a second view, you have to place them, and you'd just select a different tag to place.
