Affected views notifications when changing something in the model
I would love if on all active sheets it would show the elements affected by a change in levels/the 3D model.
Sometimes we don't realize a corresponding view which is somewhat unrelated to the changed element is affected and things get put out of place, we have to go all over the sheets everytime a little something is moved or deleted in order to make sure everything is updated with the change.
If we could have an option that you tun on or off which highlights where something got moved on all the views inserted in the project's sheets it would make keeping track of the changes so much easier! I could be certain everything that needed to be fixed or updated really is!
0
votos
