Allow duplication of sheets
Allow duplication of sheets with all included; detail items,  views, legends etc.
This would be really useful in M&E as there are multiple services to be done. Each require a different system showing but the exact same views just to be on a different sheet. It is unnecessarily time consuming, having to create each view again, make it the same size to try standardise sheets somewhat.
It would be so much easier to allow duplication of sheets - so the views look exactly in the same place, same size, same notes etc. Revit should have the option to automatically duplicate all views when you duplicate the sheet.
There are so many things that you need on multiple sheets. It would be SO much easier to have the option to duplicate a fully developed sheet and just tweak it to show a different service.
It would streamline the process of sheet production MASSIVELY.
Comentarios
You can already do this... Are you using the most recent version of Revit?
@mhiserZFHXS  Thanks for pointing this out
Wow, that's amazing. Like a wish just come true.
Started using revit 2024 only a week ago and didn't even think of trying it in this version.
Was stuck in my head as not possible from the previous versions
(and me hoping yesterday that developers would find this as a good idea)
El estado se ha cambiado a: Implemented
