Room awareness for pipes and Room awareness radius or rooms for shafts
I would like to have a schedule with pipes and their related rooms. Please make this possible. The same goes for equipment within shafts. I know that mechanical equipment can have a room awareness point, as long they are placed within a room. Sadly small shafts cant have a room space. Even if I placed the room awareness point far away from the mechanical equipment, there's no guarantee that It would connect to the right room. Imagine a valve. Depending on the rotation of the valve, the valve might pick the wrong room. To solve something like that, the valve would have to some kind search radius for which room is the closest, or it should be possible to create rooms for small shafts.
