Phasing for Views (Sections, Elevations)
When on the same Phase for example New Construction, using phase filters (ie Previous + New) should hide views set to other phase filters (ie Previous + Demo) without additional view types and filters.
The current workaround - using view types for each new construction and demo, and then additional templates with opposing filters - is cumbersome and tedious. As well, filtering all view types by phase filter to attempt to reduce the number of view types/templates created, only hides the arrows of elevations, and not the elevation marker itself.
