Room offset
Allow the base of Rooms to be dragged up not just down. On complex multi level projects where adding a Revit level for each constructed level is just not appropriate, there is a need to bound rooms by room separation lines, which this causes warnings... or bindings room incorrectly... i.e. a step in floor of 300mm should not warrant a new Revit Level, but can cause all sorts of issues. Would end up with 1000's of levels which then results in messy drawings and users modeling/snapping to incorrect heights.
Comentarios
El estado se ha cambiado a: Archived
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
