Ability to multi select when linking in Revit models or .ifc files
When in Manage links, having the ability to select multiple Revit or IFC files to load at the same time would have significant time savings. Curently the only ability is loading one at a time.
The pyApex addin to the pyRevit-Addin offers a button called Link more which does exactly what you are asking for. Still wouldn't harm Revit if this were implemented in the core product.
The tool does not work well for b360/acc project files, unfortunately.
Would also like to add .PDF files as well. Putting T24 Energy calcs on sheets for the building department is a time waster in Revit compared to AutoCAD.
