Material library slow! and tedious
@autodesk  the material library is absolutely slow and tedious.
Even merely opening the material editor can take up to a minute. this has been an issue for over 5 years.
This must be a priority to fix the elements that do not work and slow us down. Not groundbreaking new features.
For such a good software these are simple tweaks on your end which requires first attention.
To simply change or duplicate a material paint from green to red is cumbersome.
Comentarios
It really should be as fast and simple as SketchUp.
Why is it not? How are Autodesk Revit creators okay with it?
Yes, faster to open, please. And faster to make graphics changes. For example, it can take several minutes to simply change the surface pattern color of a material (wait for the spinning wheel while it ripples through all of the affected families).
Having trouble with material editor and found this thread. It is horrible... keeps crashing the program, sometimes slow when changing a mark, sometimes not. It's unbelievable at this time in the 21st century Revit still has not solved this... uggg
