Could you expand on the properties that the asset would need and the use cases for the asset? Also, how would you expect to see the asset and its properties exposed in the interface?
Properties would be the STC (sound transfer coefficient) of the material. Add that to the STC of other materials and we'd have an STC for a wall for instance. Also, it hopefully could be something that could reported in a schedule that way as well. The asset would just be the starting point of being able to do all of that. I'm not sure what you mean by your last question. It would just look like any other assets. It would be a tab. I'm sure that an acoustical engineer could tell you all the parameters that would really make it up. But that's the basics of what I'm looking for. Thank you.
