Active Workset as a Parameter selection in View Templates
On a multi-discipline model, such as an MEP model, sometime the correct Workset isn't switched to the related discipline and some backtracking occurs in order to put the components to the correct Workset. Since View Templates can be used to create the variables views for each discipline, couldn't including an option for a default active Workset for a particular view alleviate this issue?
