PDF Hyperlink to direct to the detail, instead of the entire page
Currently PDFs out of Revit have hyperlinks defined for sections, elevations, view references, etc to point into the entire sheet. It would be great if it could point to actual detail (zoom?) on that sheet, instead of going to the sheet itself.
Comentarios
This is a massive area of growth for Revit that I'm not too sure they are paying much attention to. There is a massive amount of information within Revit that is lost when its exported to PDF. Your idea would probably be the easiest, but they should also be looking into making other items like tags more interactive once exported to PDF. We should be able to click/tap on a door tag in a pdf and have a tool tip or some other window pop up that shows chosen information about that door, like height, width, door type, etc.
This would make working with CDs in the field infinitely more efficient.
