Changing Piping System Classification in Revit MEP
There should be a simple way to divide systems up when modelling. There are often times where one wants say part of a duct to be return and the other part to be supply or exhaust. Or hot water return connecting into a supply line. Or domestic cold water connecting into the recirc. It would be nice if there could be a simple division of system without screwing all the analysis tools... Like using "split element" as a system separator. That would avoid having to not connect things for the systems to be different.
Comentarios
