Pipe Families being able to have alternative connector type ends
pipe systems can have different end connector requirements, flanged one end welded the other. is it possible to introduce the option to have alternative connector type ends to allow pipes to have flange/butt weld pipe in the same routing pref system?
Comentarios
In general, they just have to separate accessories and fitting from the flange/weld system..
thanks fruity, not always the case it will try and bring in individual flanges at butt weld points if it has a flange within the routing prefs.
