Apply Linework overrides to the dots that appear at every intersection.
When using the Linework tool to override lines (usually just making lines invisible), there is almost always a visible dot left at the intersections of the lines you just hid. It really kinda defeats the purpose of hiding the lines if there are still visible elements left over. I understand that these are just lines at the Z axis to the view, but why are these even being show in a 2D view?
Either hide all Z axis lines that can't be selected or overridden in the 2D view, or make it so those lines/dots can be overridden as well.
Right now I have to override all the lines I can and then go and put masking regions over the remaining dots. In which case its faster to just hide the entire element and draw it using lines/regions which completely defeats the purpose of modelling it and makes the Linework tool kinda useless.
