"Date" parameter type
It's tough to do any real Facilities Management without having a Date parameter type.
I'm talking about a parameter where you could add 60 days to May 10 and end up with July 9 (if my math is correct)
This would be not just Text, but a parameter that would be (behind the scenes) something like a Julian date.
Currently, we can make Text, Integer, Number, Length, Area, Yes/No, etc. Type of Parameters.
Sure you can create a Text parameter and put anything in there you want, but it's just dumb Text.
For Facilites Management we need to be able to take a parameter and add 9 months to it for things like Lease Expiration, or 2 years for Carpet Replacement, or 60 days for Equipment Maintenance, or specify a Delivery Date forConstruction Sequencing.
The formatting should be part of the output, similar to how you can set your Length to Decimal or Feet & Inches.
Comentarios
I SHOULD THINK THIS PARAMETER TYPE IS CRITICAL TO BIM! Perhaps a Date-time format would be more appropriate, and one should be able to pick a particular instant in time using commonly available calendar controls.
Date type parameters, where you need so select a date from a calendar, instead of plain text. Then it can be set in the Project Units how the format is. Then all dates in the model will have the same format.
Similar to when you select a date for Sun Settings during a render.
This would be very helpful for Facility Management
I would like to see a time based parameter so that one of my users can turn off the "NOT FOR CONSTRUCTION" stamp on our title block for a few hours, but if they try to reprint the drawing the next day, it will by default return to saying "NOT FOR CONSTRUCTION" as things may have changed on the drawings based on work elsewhere in the project (those parametric changes are a double edged sword) and the drawing needs to be reviewed again before it can be printed. This would provide me with a similar effect to a temporary hide, except that it's a bit more fool proof and doesn't require me going to each and every sheet during setup to copy the "NOT FOR CONSTRUCTION" tag, it's just part of the sheet boards family.
I just want to elaborate on my earlier post. As collaboration becomes more important to the design world it also seems important that the data we share be universally formatted. For a single organization that sets it's own internal standards the use of a text parameters as a work around for dates may be ok. But when models are shared between organizations this work around seems less workable. I expect that in the near future we will be creating models that our clients will use as ongoing facility management tools. I also expect that using dates in maintenance schedules for equipment and fixtures would be a very good use for that tool, but having dates not really be dates is a problem.
Date parameters will need to understand how many days in a month and a year and it would even know the leap years. I know that is not all that easy.
A time/date parameter where the units in use could be set could also be used for a more flexible fire rating designation.  It would be nice if the same field could read "20 Minutes" for one element and "2 Hours" for another.
*BUMP*
I second that bump. Emoticono feliz
hello
Added a date parameter in the parameters Properties.
 Did you add the Date parameter successfully? Or do you hope to see it there?
Just make sure I can choose what the date looks like, preferably in the options and not use the default Windows settings, because for me at least, that is different then what I want on my drawings.
I'm finding it difficult to believe that both Date and Time selections do not exist as a Common discipline Parameter. It is essential for many O&M and Facilities.
Currently need this in my for nested families .rfa:
MANUFACTURE DATE                  Value: (DATE)
INSTALL DATE                               Value: (DATE)
LIFE DURATION                            Value: (YEAR TIME or MONTH TIME)
END OF LIFE                                  Formula: (INSTALL DATE + LIFE DURATION) This could be a positive or negative number.
The idea is to tell client when parts need replaced. Or if they past due for replacement.
It will be great to have the possibility to add "Date" parameter  into a family annotation.
Currently, there are several parameters but "Date" is missing.
I give you an example : the possibility to tag in a fire extinguisher into family object in aim to filter in Revit project the inspection date !
I attach the picture where the type "Date"  could be added.
Olivier
There's already a post about this:
https://forums.autodesk.com/t5/revit-ideas/quot-date-quot-parameter-type/idi-p/6323051
Please search and upvote existing Ideas before posting.
Hi Oliver, This is an old request and it's a mystery why this has not been solved. I remember this issue being raised almost 15 yrs ago at a conference so we are still entering date values back-wards as text.... Perhaps it's more complex to solve than we realize but it would be great to have. Cheers M
Je vote OUI !
Aujourd'hui j'utilise des paramètres nombre entier type AAAAMMJJ pour incrémenter des dates et pouvoir filtrer avec des paramètres égal, supérieur à ou inférieur à mais l'horodatage me parait indispensable pour l'avenir.
Bonjour,
Plusieurs demandes restent sans réponse :
 les escaliers pour la structure.
l'étiquette de semelle filante dont l'orientation est soit horizontale soit verticale et ne suit pas l'orientation de la semelle.
Et j'en passe.
Peter
Bonjour,
Je vote "OUI"
Observer
Observer
Ce paramètre date devrait également être ajouté à Revit 2019. Merci.
I believe above comment translates to: "This date setting should also be added to Revit 2019. Thank you."
Je vote OUI / YES !! Ca serait d'une grande aide !
Seems this should be easier to integrate now that we have Global Parameters.  Real dates could be assigned to Project Phases.  Equipment could even be relocated as part of Phased work!  And, a side note, we could do away with Phase Filters and simply use View Filters to manage appearance of Phases with more control than Phase Filters currently allow.
For example, i need to program the maintencance, and i wuold like to set up a schedule like this:
LAST ISPECTION                        Value: (date) ex: 01/01/2019
NEED FOR MAINTENCANCE     Value: (yes/no)
MAINTENANCE DONE               Value: (yes/no)
NEXT ISPECTION                       Formula (Last ispection + frequency of ispection) = 31/01/2019
Frequency of ispection             Value: (number) ex: 30
I can easily do this in excel, but i want to do it in a schedule inside revit, then maybe use a plug-in to export deadlines and have a reminder on company devices.
Hi all,
Any good news about this marvelous idea?
I would like to push the reflection further.
I think Revit should natively integrate date settings for all objects (like current phase settings). Timing is an important piece of data in our current workflow.
  • Each view has a start and end date, the graphical rendering of objects is dependent on these dates (the original Revit phase graphics also work with this process!)
  • Filters can query these parameters as well.
  • This should also work with the linked Revit models ! (and easier than the current phase mapping)
In a second step, complex phasing operations (link with Navisworks) could be managed by an additional tool (such as Autodesk interoperability tools).
(In my examples, when you read "end" understand "demolition")
2024 and still nothing
Dear Dev team, This date parameter is essential for several sectors that require it. Please can you provide us with an update. I don't understand why this would be that difficult to add? There are some great comments in this thread.
ajouter la date d'aujourd'hui par un clique
Bonjour @mehermnifi,
Pourriez-vous développer votre idée ?
En l'état, ce n'est pas clair du tout...
El estado se ha cambiado a: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing. (Note that Accepted Ideas may not be immediately available.)
The Factory
Happy New Year 2025! This topic is 9 years old now... LOL
