Standardize your Revit models
For the whish list make this a standard:
https://reope.com/nightrunnerhttps://reope.com/  and
https://www.youtube.com/watch?v=7LzAm7lCxcE
A tool that makes families, Types and Settings across multiple Revit files identical, and saves large project teams countless hours.
The job of manually synchronizing Revit data can be solved.
Comentarios
What do you mean make families identical in different models? Like you have one door family in one model, and another door family in another model, and you want to make them the same family?
Hello @mhiserZFHXS, did you check the link in the post to the website and to YouTube?
@pascal_deleeuwNo. I typically don't click on random links posted on forums, and I don't usually take the time sit through a YouTube video. If you're looking for support for an idea, its best to just write it out in words.
As @mhiserZFHXS stated, you need to describe your idea in your own words. Nobody is going to click a link (especially that one, I can't even tell where the web address starts and ends).
You can add links if you want but people need to have an understanding of what you are asking from the get go and if they want more info they can click the link or not.
@mhiserZFHXS
Making sure to deliver consistent design data when working with multiple models in one project.
One single source of information one database that contained important design data in a project. push it to all models.
Materials, Families, Types and Settings across multiple Revit files identical.
@pascal_deleeuw
That is still an incredibly vague description of what you want... But it sounds like this is something totally up to the user. You want all of your models to be consistent in a particular way? Then create them that way.
