Tag families should rotate according to assigned angle in a dependent view
The tag in Revit should rotate according to the assigned angle in a dependent view. Currently, they rotate in the dependent view if the "rotate with component" option is selected. However, the tags which have a specific angle assigned do not rotate as expected in a dependent view.
In the below screenshot, notice the difference in rotation for tags with "rotate with component" & the green tag with the angle assigned. The rotation can be compared with the sample text.
Comentarios
Community Visitor
Community Visitor
Yes, I agree.
A needed one.
I have not given any angle, but it is rotating automatically in the dependent view, while in the view it is correct.Dependent viewDependent viewMain ViewMain ViewTag Angle Horizontal but showing verticalTag Angle Horizontal but showing vertical
