Toposolid Height Offset from Level
Please let us pre-define the Height Offset From Level when generating a Toposolid from imported mesh/points.
I generally I like it when the Toposolid has zero height offset from the level that we call Datum or Sea Level.
However, at present, it seems that the elevation height from the lowest imported point is used for this and there is no way to later change the offset without changing all the elevation heights with it.
Comentarios
