In previous Revit versions you could select Project Browser Tree elements by selecting the top element then while holding the shift key + Arrow down key, select additional items. This functionality has been removed in Revit 2024 which is disappointing because selecting multiple item now requires more mouse clicks.
Additionally I've noticed that long items loose visibility at the end of the item when renaming.
Regards
David
