Cable Tray "Systems" for automatic calculation of amount of cables running through
It would be nice to have a Cable Tray "System" like the systems currently available for Air Ducts which sums needed air quantity. If you could for instance add data outlets (data circuit) to the Cable Tray System it could then calculate the amount of data cables in a specific part of the Cable Tray System. This would make designing the cable tray width's a lot easier. This would also work for all Power Circuits which you can add to the Cable Tray System to let Revit show you the amount of cables in a specific part of the Cable Tray System.
