Locating View with Inserted / Linked DWG
We need to be able to locate the view in which a DWG was inserted / linked to be able to then delete it or copy it.
If I need to show a DWG, say a survey,  in a particular plan view and I know the DWG  is already linked with "current view only", I am in a for a long and tedious hunting process because to be able to copy it and then paste it in the same location in the desired view, I need first to locate it. Easier said than done.
Ideally this DWG would have been linked using shared coordinates but most often than not this not the case.
