Selective Visual Styles
You can set linked Revit to halftone, why not be able to set them with a Visual Style independent of the host project model? Linked files could be set to Wireframe while the active host model could be set to Hidden to allow for more definition between the two? I work for a plumbing contractor and it would be beneficial to have our modelled piping be set to Hidden or Shaded while the linked Architectural model be set to Wireframe. Currently, the Visual Style setting applies to everything visible in a view.
0
votos
