Create room data sheets
OK, so your can pull out data from rooms into a schedule... But thats a simple schedule.
We need the ability in Revit to format the data into a traditional room data sheet that you would find on most Architectural projects - an A4 sheet with the room data laid out in a report format.
No more crappy work arounds with exporting the data to excel then mail merging it into a report - Revit should do this stuff natively.
Its a basic requirement on most projects, as all the data required can be stored in the model then it should be easy to display it in the correct way.
