Design options > Display override to be display on the Status bar.
Next to the design option status, I would like to see a drop-down showing the display option/override for the view as there is no way of telling if the view you are working in has a display option override applied or if it is set to automatic.
This will avoid several steps of having to go into the visibility/graphics to verify if you are viewing a design option override.
