Capitalize "all", the default for the parameter "Visible in Option" when there are design options
When there are design options, the parameter "Visible in Option" has the default setting of "all". This should be capitalized to "All" to keep consistent capitalization with other default options (such as "Scope Box: None"). It is currently lowercase in 2019, 2020, 2021, and 2022 versions of Revit.
