Remove loose ends
Whenever you edit a sketch, you must not have any loose ends left in it. I propose to alter the complaint dialogue when this is not the case, to offer to get rid of everything that does not describe a proper sketch (highlighting these bits, of course) ie. is not a closed polyline. Users can opt out as b4 and continue editing manually.
Comentarios
