Multi-segment sections
It would be great to be able to make a multi-segmented section in Revit, just like the grid.
Comentarios
Doesn't this function already exist in Revit? Or do you mean something different?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Something different. I think what the OP. Is saying is foe the view range to follow the segmented section line rather that the whole thing going back the the furthest line.
That is what i would like to see happen as well
No, the segment view command can only segment a section orthogonally. I was talking about drawing the section line just like you would draw a multi-segmented grid line,where you can specify the direction of the grid however you want.
Example, how would you draw a section like this?
I had to use 3 different sections to match this section shape and than later join them together in an external application to make them look good.
I have the same problem just now, creating a long section of a segmented ramp same as this (bottom image).
