API handle undo
API handle undo. At the moment there is no handler. If a user deletes an element, you can track that, up until the point they undo, you have it recorded as deleted, but the deletion was undone. If recording to a database, you can reconcile on sync or save, but this adds too much down time to a user.
Comentarios
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
El estado se ha cambiado a: Archived
It seems like this is handled by the "DocumentChanged" event (see https://forums.autodesk.com/t5/revit-api-forum/undo-event/td-p/4788727) so this should be marked "IMPLEMENTED" or (more likely) just moved to the support forum.
