Allow multiple sprinkler selection to "connect to" a pipe.
When selecting multiple sprinklers, please allow the "connect to" command to connect the selected sprinklers to a pipe at the same time instead of doing one sprinkler at a time.
The "generate layout" command can be used but this does not really match the normal workflow because typically, the pipes can be layout first, most of the time the ceiling, lights, diffusers are not ready and fully coordinated on the early stages of design but we can already model all the piping once the structural is ready. When all the sprinklers heads are modeled later in the design, and we will connect to the pipes, we have to do it one sprinkler at a time which takes a lot of time. If we can select maybe three or five sprinklers at a time while in "connect to" command, that would help a lot.
DG
Comentarios
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
El estado se ha cambiado a: Archived
