revit filter color standards
Would Love to see it possible to create a filter, set the color/pattern/linetype, etc. for that filter in the filter set-up. We use the same filters on multiple viewtemplates with identical color/transparency, etc settings. It would be so much simpler and such a time saver if we could set these standards at the filter creation screen with overrides per view-template as it is now for those who want to change it on a per sheet basis.
Comentarios
