QR Code for BIM Model
Is there any possibility to create QR code for BIM Model?
Comentarios
And what should the code contain? Where do you want to place it? How do you expect to use it?
Maybe an annotation type object that could be placed on a sheet or view which has a URL or other text property and then Revit encodes that URL/text as the QR code.
Then scan the code from a printed sheet with a phone and it brings you to the same sheet on the project's CDE?
@Simon_Weel actually code need to carry 3D model which need to place in Construction Site.
Answer: -
I got the answer from Fuzor and Autodesk Support Team.
@MOR-ConorMacken
Requirement.
            1. To Generate QR-Codes for BIM Model using Autodesk Application like Revit or Navisworks?
      2. A person working at the site can be able to view the models by scanning those QR-Codes placed at the site using Mobile.
