Saved sets of working views
Feature Description: In the Project browser add a section for "Saved View Groups" that can be selected to automatically open multiple views at a single time.
Working Problem: The single largest issue that slows down my work is having to manually switch between sets of views. I don't work in just a single view when working to solve a problem, I think this is common across the majority of those who use the software. I am always working on a single problem while having multiple views opened at once, and when switching between view sets, I have an area of a project that is best captured by opening 6+ views across a variety of types (details, 3d views, schedules, plans, sections). Conceptually working in sets of windows has to be managed by naming conventions in the project browser or by ones own memory. Capturing these together would save time resolving a problem when diving into a particular area for work after leaving it to solve other problems.
The closest thing to this is placing views on a sheet, and working across model views in the sheet, so it is creating a feature that is fundamentally how we think through and use construction documents. It's not an edge case  wish list item. All forum answers to date are either focused on browser organization / naming conventions, or just that it can't be done right now.
The Long Vision: Imagine a future where you select a modeled component, and then select show > Primary related views / All related views ... and then you have all views / schedules / etc. open at once that are related to this particular building component. This multi-faceted heads up display of a single conceptual piece from any or all relevant areas and can assess any changes that need to be made with the help of the models internal data structure.
This is a future feature that is worth your time to consider and develop.
