An issue was brought up on nudging sloped piping (CaseNo:19650520) and how pipes connected directly to P-traps will lose the slope when other connected pipes are moved. The Dev Team was able to duplicate the issue and stated it was down to the pipe connectors not recognizing the slope on the pipe, therefore defaulting back to an aligned connection between the pipe and fitting. It's fairly common for an entire pipe system to need to be adjusted up or down by fractions, and nudging with the arrow keys is the easiest way to do this. The only way currently to adjust an entire system and keep the slope would be to select all pipes connected to fittings and p-traps, then move them, which takes much longer to do. Since sloped piping is integral to any project, and trusting that the sloped piping will not change unexpectedly is necessary to trust what is coordinated, a fix for this issue must be implemented.
