Isolated Ground Tick Mark
I would like to be able to add an isolated ground tick mark in the Electrical Settings>Wiring. My company's standard (which I believe is also common throughout the industry) is to show an isolated ground as a long tick mark with a dot in the center of the line. Currently, there is no way to do this, as the only options for tick marks are Hot wire, ground wire, and neutral wire. I know I can add a second ground wire tick mark to any wire to show the second ground wire, but there's no way to differentiate the isolated ground tick mark from the regular ground tick mark.
Ideally, this would be a property of the circuit so that the isolated ground tick mark could be added automatically with the "calculated" option.
Below is a picture of what I would like to achieve for a homerun with one hot, one neutral, one ground and one isolated ground.
