Window and Door family Cut per Project not family
I would like the plan cuts for Doors and Windows to be controlled by the project and not the family. The reason is that I have Transoms, such as an exterior metal panel above, or glass transom above, which I want to cut for detail reasons since they are modeled correctly. Currently Revit only allows to show the cut of the plan from the family of Doors and Windows, and more only allow one, Please, Please change this. Why would I want the family to control where it should cut? All other families which allows cuts show correctly, and more it is not necessary for me to make them nested panels above as they are pretty simple. See example Below.
All Section cuts show as below as this is the appropriate View Range for the family in plan view.
