Let dimension's value be able to make in a schedule
If we can make a schedule of of the dimension's value, we can monitor and highlight where the fractional dimensions are and make necessary changes on the walls.
Comentarios
Why schedule dimensions if you can schedule wall length/height/width directly from wall category schedules? You can even use conditional format to detect irregular values. Anyway, this idea wouldn't work because dimensions aren't attached to walls or specific categories, only to lines/points of visible elements. Hope this will help in case you were experiencing issues of this kind.
Because, a lot of time, the dimension is used to measure the space between two walls (like corridor width), not the wall length itself.
I think the tennants should be allowed to schedule whatever they fancy. Why not text and detail lines while we are at it?
