Revit level labels offset function - like jog
It would be nice to get an automatic feature that would allow all visible levels in a view to be jogged as needed, to not have overlapping level text/descriptions/level heads
With Revit, you can jog (add an elbow) to the level line in a section to offset the level name when they overlap
- each one, each view - you need to do this - can be very time consuming
- similar to other programs that allow a jog for overlapping text in ordinate dimensioning for example.
This would go along with the previous posts regarding being able to change level lines & grids different from the 1" (25.4mm) beyond crop or scope box.  Both items would be nice.
