Support input coordinates for copy, move and draw commands
Could you make it possible to input coordinates in x and y directions when copying, moving or drawing objects?
For example, currently to move an object in two directions, it requires 2 move commands. Each allowing you to input coordinates. Could you make it possible to input both x- and y-coordinate in one command?
Maybe even implement the advanced input-system you use in your old-school product Autocad? ![]()
Thanks in advance!
