Distinguish the names of the parameters in PDF export dialog and add information in the warning.
It would be great to see the difference between the "Sheet Number" and "Sheet Name" parameters related to Views and Sheets in the PDF Export dialog.
At this point, the parameter names are exactly the same for sheets and views, resulting in a warning when sheets are exported with parameters used from the view set.
A message in the warning could also be added, for example, 'The parameter "Sheet Number" used in the sheet naming rules refers to views.'
