Labeling of multi-layered floor slabs - walls - roofs
It has already been written several times in various forums as a question - wish - problem, and we have it too.
The multi-layer elements (floor slab - walls - roof) are built with type properties, is 3D, i.e. if you adjust the thickness, the element is also adjusted.
The wish is to have a labelling, such as a room labelling, which can be inserted into the view, which takes the order into account, and which has a new column with comments.
There is a partial solution with the component list, which I cannot add to the view, only on the plan / layout, does not take the sequence into account.
Note that if it has a slope, it does not give the average value, but the smallest and the largest dimension, e.g. 30-60 mm.
If, for example, you have the raw floor as one element and the underlay floor is another element, then combine them and the entire floor structure is also included in the labelling.
The title labelling should be freely fillable.
Comentarios
Indeed a good Idea, for any layer based objects. (Walls, Floors, Roofs)
