Override tag-alignment in views
Please could you make it possible to manually override the alignment of tags in views. Right now when for example a detail view is finished, it could look like this:
But when one tag is altered, alignment of that tag is set according to the alignment in the tag-family itself, so the alignment is broken:
It would be great if aligment of tags could be overridden, for a bunch of tags at the same time, in one click. Thanks in advance!
