An Internal origin visibility for sheets (On/Off) should be added to identify the 0,0 point on sheets for sheet setups. Right now we have to link in CAD files to accurately locate the origin for placement or verifications sheets haven't moved off the origin which cause sheet setup to land off the page.
This origin point is equally critical in consistency between CAD setups, PDF and Revit sheet setups.
