Graphically selecting/changing nested families keyed to family type parameters
Currently, you need to change the parameters of the parent family in the object properties menu to see changes of the nested family i.e. door leafs if one nests multiple door leaf families in a parent family.
A small graphical improvement would be to be able to tab and select the nested family if it's attached to a family type parameter and then being able to change which nested family is used. If the label is an instance parameter then no warning would be displayed. If it's a type parameter then a prompt would appear that all instances of this type will be changed.
