Panel Schedules - split between sheets
It's basically impossible to fit a 64 to 96 pole panel on any size sheet, even A1.
For the next release of Revit, please allow Panel schedules to split across multiple sheets in the same or similar method as normal schedules. The panel header information would remain at the top of each sheet. Ideally the schedules should be able to fit as single column on multiple A4 sheets.
Thanks.
